Brief Description: Rolled left elevator leading edge
Rolled left elevator leading edge per plans. Used a 1" pipe to get the initial bend going, and then went to a 1 1/4" pipe to continue the bend. Finished off by clamping the skin sandwiched between a board and the 1 1/4" pipe and bending the skin nearest the spar. Lots of work, but the results were pretty good. I doubled up on the rivets and added some extra bend at the last 1/8" of skin past the rivets to get it to lay down well.
