Brief Description: Prep Left Elevator Stiffeners and both skins
Prepared both elevator stiffeners and skins per plans. Drilled right elevator stiffeners to skin and dimpled both skins and elevators. Considered whether to use the bent tab on the left elevator per plans or use a mini rib similar to that used for the trim tab. I think I'll go with the mini rib. It's more work, but the bent over trim tab enclosures just dont' look aviation quality to me. Time is money, and I work cheap!!
