Brief Description: Prime Right Horizontal Stabilizer Skin and Rear Sp
Primed Right HS Skin mating surfaces with Sanchem 6100 system and Sealer #2 as with left. Primed Rear Spar parts and front spar angles (HS710 and 714) with Akzo Epoxy Primer. Used Preval sprayer system. Worked pretty well, but the finish could have been better. It was a little windy in the garage, and that made spraying a little harder.
