Continued drilling the main spar holes using the skin as a guide. Disassembled everything and make form blocks for HS706 and HS707. Worked down the nose areas that were causing bulges in the skin and re-deburred everything. Reassembled, and the bulges were better. Set in the forward inner spar nose piece (HS-404) and clamped in place for drilling.
