Brief Description: Adjusted canopy frame width and contour
Adjusted width of canopy frame and contour of canopy frame side square tubes by bending w/ nylon ratchet straps & direct pressure bending. Final result slightly narrower than plans (1/8" to 3/16"), but expect canopy to flex to wider dimensions when installed. Both side square tubes showed SLIGHT buckling when final dimensions were reached. Seems tha bending w/o buckling is difficult or impossible.
