Adjusted rear hoop on canopy frame to fit fuselage rear deck. Bent using jigs screwed to table. Also did final tweeking by twisting whole frame at once. Trimed plexi rear edge per plans ~1" aft of rear hoop. Multiple on - measure - off bend - measure cycles later, rear plexi edge fit rear deck reasonably well. Trimed lower side edge for clearence as plexi was clamped to frame for drilling per plans.
