Brief Description: Mounted the brake pedels in the footwell
Mounted pedals per plans. The only difficulty was getting a spacing that worked out on the alternate mounting holes. I drilled multiple holes along both longerons where the pedal assembly mounts (used angle drill again). Later, I found that drilling the corresponding holes in the center mount resulted in some holes without proper edge distances. After some consideration, I decided that this will be no problem as the role of the center mount is just supplemental support. All the loads are towards the bottom of the plane (no neg G maneuvers!) and the mounting bolts will provide more than enough strength as drilled. I may make a two hole cap piece to make the assembly even stronger.
