Brief Description: Fit Flap Bearing Blocks and Started Step Installat
Got a lot done today!Fit the flap actuator bearing blocks per plans. Added bottom rivet in F-711C bar on one side at the rear of the fuselage. We were unable to complete the other side satisfactorily - will go back and complete later. Started installing the steps by cutting holes in the side skins and ribs per plans. I first cut the hole in the skin with a hole saw in the drill. This was a little scary, but it worked fine. The hole in the first rib (inboard) was cut with the same hole saw mounted in a drill bit extension from Lowes. I used a 1" drum sander chucked in the drilll to finish holes to the correct size and clearence for the step mounting tube. Next step is to bend and trim the steps themselves!
