Brief Description: Final assembly of trim tab with mini-ribs
Completed final alignment of trim tab with elevator according to plans. Modified procedure as follows to rivet trim tab with mini-ribs:Cleco trim tab together with clecos in all holes. Fit hinge to elevator per plans. Drill bottom mini-rib holes while ensuring trailing edge alignment per plans.Dissasemble trim tab and dimple bottom skin holes and bottom mini-rib holes. Squeeze 426-3 rivets attaching top skin to mini-ribs. Used MK-319-BS blind rivet in last hole.Reassemble trim tab with clecos and check alignment again.Squeeze hinge to trim tab and elevator.Attach bottom of trim tab skin to mini-ribs with MK-319-BS blind rivets while ensuring alignment. This procedure worked well for me. After the trim tab was installed, I made a new E-616PP cover plate to reposition the electric trim servo for better alignment with the trim tab horn.
