Heat cut all holes using high lift wing supplement templates for leading edge and trailing edge, completed heat cutting all wing rib holes leading and trailing edge. Completed compression strut and diagonal strut installation torquing all bolts to the proper specs. End ribs were inserted last after required alterations for high lift wing. Lift strut to wing spar attachment completed. Wing riveted at leading edge to secure tension of wing covering.
