Brief Description: Final Radiator Assembly / Hose Routing
Radiator fill tank attached to upper engine inlet, hose cut to length and run below, attached with hose clamps. Vacuum hose attached to upper engine outlet, small red hose widener added then clamped as supplemental instructions suggested. All bolts tightened along with all hose clamps, Remaining hose was cut in half allowing two protective pieces to be added using tie wraps, preventing chafing.
