Brief Description: Choke Cable To Aft Upper Tri Bar Assembly Attachme
Choke cable attached to aft upper tri bar, cable run as per diagram and standoffs created to prevent cable rubbing/chafing. Choke cable attached to carburetor and adjusted for use from cockpit.
