Lined conduit cut in half. End caps loosly insterted, brake cable insterted, end caps crimped. Brake handle attached to control stick and assembled as per diagram on page 3-109. Brake cable routing done as per diagram on 3-111, 3-113. Slack adjustment max at full forward CG, so this allows slack at mid and aft CG setting. Standoffs made to keep cables from rubbing on frame. Brake cables adjusted to allow brake lock at full squeeze.
