Root tube arrangement noted and marked. Wing spart channels attached. Root tube front cap installed and riveted in. Trike general arrangement noted on page 3-8 for reference. Aft tri bar assembled. Triple tongue fitting and eyebold attached to fwd tri bar. Forward tribar assembly attached to root tube upside down for ease of attachement. Axle shaft and brake arm attached. Brake bands attached. Shoulder harness tube attached to landing gear down tube. Proper rotation for seat belts noted. Landing gear down tube attached to axle. Axle channel attached. Aft upper tri bar attached. Landing gear down tube to root tube attached. Nose strut, tension strut and axle attached. Nose gear support assembly built and attached. Axle strut, nose strut and tension strut attachment. Seat support down tube to root tube attachment. Seat mount assembly attached Seat mount assembly was attached in the FORWARD position for a single pilot.
