Jim's Web Site
Date:  2-1-2012
Number of Hours:  3.00
Brief Description:  worked on panel
Cut a number of instrument holes in the panel and built "Jim's easy jack bracket." The bracket is built from plastic decking and it works very well. Used two 1/4 inch bolts by 4 inches, 4 washers, and 2 wing nuts. Clamp the deck on a bench and cut the notch with a hacksaw and/or just use your bandsaw. I believe the bracket will work good for attaching the wheel pants.
Hole saw cuts in panel
Here's the panel I purchased.
