Jim's Web Site
RV-9A
Forward Fuselage
3-24-2012
Cowl and baffling
Build a 2.25 inch spacer for the prop extension pattern and worked on the cowling. I also removed the original panio hinge on the side of the firewall forward and replaced it with the correct 1/8 inch hinge on the left side.
RV-9A Home
1695
Airbox
Baffling
Cowl
Elevator
Filberglass tips
Forward Fuselage
Fuel Tank Left
Gear Fairings
motor
Panel
Right Aileron
Trim tab work
Wing Tips
Wiring
