Brief Description: Working on brakes, tires, axle, and more
Worked on getting everything ready to install the axle's on the plane. Installed the wheel on the front fork. Drilled the bolt pass through hole for the front fork through the firewall. Drilled a number of holes larger in the firewall. The panel that I purchased from Bob Albrecht just came in today. All looks good.
