Brief Description: Work on a number of different items inside the fus
Fuselage work. Wiring and bolting on the HS and VS, and then removing the VS because the holes for the wiring for the tail postion light was to small. I'm sure the VS will go off and back on many times. I was looking at another RV9 project today and he was bolting on the HS & VS and he had not drill a hole for any postion light in the aft fuselage, I'm sure he will have the same problem. Over time you get better at taking the parts off and then placing them back on. To drill the holes bigger in the tail cone I inlisted the help of a very small granddaughter who delivered the drill to the rear of the fuselage. If you are working on these holes now and it is prior to installing the VS, HS and rudder, drill big now!
