Brief Description: F-703B Angle for panel bracket.
Many hours of cutting on the panel angle bracket F-703B to make it fit on the back side of the panel. It will still take a little more work on my next visit to the shop but it is looking good. Also, cut the left panel rib F-745-L for additional space to install the EFIS in the panel. I'm still up in the air over the right EFIS to use for my type of flying, however, I'm sure time will tell, I just know I will need more room on the left side of the cockpit. This is a very important part of the building process, it will certainly add to the value of the plane if it is done right. Also, I don't need to be removing parts after I rivet them in place because I was not thinking prior to riveting them in the first place.
