Brief Description: installing brake lines and many other items
I have been working on the brake lines on the inside of the fuselage, the right side looks good and the left side will need to be replaced. It is to short and few of the bends are too sharp along the floor. It would work if it were long enough, however,I will order more ATO-032x1/4 tubing and see if I can do a better job on the left side install. Also, need to get the main brake line for the connection to the brake cylinder left and right side.
