Jim's Web Site
Date:  4-20-2008
Number of Hours:  3.00
Brief Description:  Rudder attachment and counter sinking rudder stops
Over this weekend I attached the rudder and it runs really smooth, also, did a little fiberglass work on the HS tip. Next I will take it all apart and rivet the tiedown inplace, and finish up riveting the balance of the tail cone, rudder stops, HS attachment bracket, and rivet on the two small fairings for the rudder cable past through. It's a very slow process, but it's starting to look like a plane, that may fly someday.
Rudder attached and fiberglass tip work.
Rudder stops drilled and counter sinking completed.
2 small fairings for rudder cable.
