Jim's Web Site
Date:  12-16-2007
Number of Hours:  8.00
Brief Description:  intalling the fuel lines in to final resting place
I worked on Sunday this last weekend installing the fuel lines through the brackets and gear, the best way to do this part of the process is to get each line form to size and then start working it through the brackets with the brackets removed and then into the gear leg and place the gear leg through the hole and continue by tighting up screws and bolts. I used rubber groments for the fuel line in each bracket in the lower hole to hold the fuel line inplace, I could not get the lines through the plastic groments provide by Van's. I'm sure I will be removing these lines again but I sure hope not. Next I will try to install the brake lines left and then right, however, I need to make up two small blocks from poly foam to hold all the lines under the forward tunnel, so I'm looking for some poly foam to make these fuel line and brake line containers. I will take a photo after I get them install.
through left bracket.
final look and hooked to valve.
just another view .
just another view .
