Not much time at the hangar over the last 3 months. We have made a few trips out of State for vacations with family and friends. I have been working on the oil return lines, after installing the lower center baffles. I purchased the center baffling from a party in Wyoming for $85, I found that the oil return lines would need a few more bends to get them to re-connect. One needed to be replaces and three of them I could use. Also, I continued working on the alternative air and the carb heat box. I purchased the pipe mount carb heat through Vans and need to cut off an 1/2 inch to get it to work with my air box. In addition, I installed all the cruse plats and the cross over pipes to the manifold. I hope I'm doing this part in the right order. I will post a few photo's. Yesterday I did get a little time to fly the Cardinal.
