WebAir Web Site
Date:  2-9-2008
Number of Hours:  1.50
Manual Reference:  Section 8
Brief Description:  Elevator bellcrank install and connect
Installed the elevator bellcrank and connected push tube. I may add the low profile washers here to provide more radial travel of this push tube during aileron input. The print only calls out the low profile washers in the foward position of the push tube. There may also be some interference with the bellcrank itself that won't be alleviated with the low profile washer. Don't know until the ailerons are connected and travels are set.
