-DRILLED LENS TO SKIN -DRILLED LENS-SKIN TO #30 -DRILLED LENS TO 5/32 AND COUNTERSUNK -PREPPED REATINING STRIPS & RIVETED NUTPLATES ON -INSTALLED LAMP ASSY INTO BRACKET -TRIED TO INSTALL LENS BUT REALIZED I'D INADVERTANTLY FITTED A LARGE NUTPLATE ON RETAINING STRIPS, SO REMOVED NUTPLATE AND INSTALLED THE CORRECT ONE -FINALLY INSTALLED LENS ***LANDING LIGHT INSTALLATION COMPLETE, EXCEPT WIRING AND MOISTURE BARRIER TAPE, WILL INSTALL THAT ONCE LIGHTS ARE ADJUSTED
PICTURES- 1691-1696 GOPRO PICTURES RIVETS - INST 14 - REM 2 WING RIVETS - INST 994 - REM 33 TOTAL PROJECT RIVETS - INST 3313 - REM 86
