-CUT OUT AND LAID TEMPLATE OVER LEADING EDGE -MARKED CUT OUT LINES -CUT OUT ROUGH LANDING LIGHT HOLE IN THE LEADING EDGE -FOUND IT REALLY EASY TO CUT WITH THE DREMEL CUT-OFF WHEEL & ROTARY BURR
***FOUND THAT I'D FITTED THE TEMPLATE UPSIDE DOWN WHEN I MARKED SO THE CUTOUT WAS 1.5" INBOARD OF WHERE IT WAS SUPPOSED TO BE
PICTURES- 20160114_003949, 003959, 004833, 012224 RIVETS - INST 0 - REM 0 WING RIVETS - INST 970 - REM 31 TOTAL PROJECT RIVETS - INST 3291 - REM 84
