-CLEANED UP ALL PARTS WITH MEK -CARRIED OUT CONTINUITY CHECK OF CAPACITIVE SENDER PLATES/PLUG -CARRIED OUT FINAL CLEARANCE CHECK ON FUEL TANK BAYS -TOOK VIDEO OF CLEARANCE CHECK - SEE VIDEO 20150420_154440 -SEALED TERMINALS ON IB SENDER PLATE -RUN SEALANT ALONG BAFFLE RIVET LINES ON TANK ASSY -RUN SEALANT ALONG RIB AFT FLANGES - EXTRA SEALANT ON END RIB CORNERS -INSTALLED T-702 BAFFLE INTO PLACE WITH A CLECO IN EVERY SKIN-BAFFLE HOLE -RIVETED ALL RIB TOP AND BOTTOM HOLES WITH POP RIVETS IN ALL BUT END RIBS & SOLIDS IN THE END RIBS -INSTALLED ALL T-712 Z-BRACKETS USING POP RIVETS IN CENTRE RIBS AND SOLIDS IN END RIBS *HAD TO GRIND A FAIR BIT OFF MY POP RIVET GUN TO FIT IT ON THE Z-BARCKETS -RIVETED ALL LENGTHWISE SKIN-BAFFLE RIVETS WITH 3.5 SOLID RIVETS -RUN SEALANT AROUND T-708 COVER PLATE & INSTALLED ONTO TANK AS USUAL I MADE A HELL OF A MESS BUT IT SHOULDN'T LEAK
EXCEPT FOR CLEANING UP FUEL TANK IS COMPLETE, IM GLAD THATS OVER!!
PICTURES- 1623-1642 RIVETS - INST 183 - REM 0 WING RIVETS - INST 751 - REM 25 TOTAL PROJECT RIVETS - INST 3072 - REM 78
