-Drilled fuel tank assembly -Drilled Fuel pickup holes to 411 panel -Cut out 711 stiffeners which I hadn't done previously -Tidied up stiffeners -Drilled Stiffeners to to skin -Countersunk Fuel Tank skin only on baffle row of ribs -Drilled spar attach screw holes to #19 -Fabricated T405 attach angle, I didn't have a bandsaw or similar so I had to make do with a hacksaw, linishing belt & scotchbrite wheel -Deburred T410 plates -Drilled 405 plates roughly as shown in plans -Clamped 405 & 410 Reinforcement plates on end ribs & drilled -Drilled & Clecoed VA112 drain flange to tank, used rod end bearing to align hole in tank skin. -Have to skip over fitting the cap assembly as I ordered the delux cap and am still waiting for it to arrive.
PICTURES- 1168-1181 RIVETS - INST 0 - REM 0 WING RIVETS - INST 447 - REM 24 TOTAL PROJECT RIVETS - INST 2662 - REM 71
