-CUT BOTH WING WALK DOUBLERS TO SIZE -DRILLED SKIN TO DOUBLER -SECURED MAIN SPAR INTO STAND -TAPPED TIE DOWN ASSY -FITTED TIE DOWN ASSY/ AILERON BELLCRANK BRACKETS WITH CENTER FOUR BOLTS AND TORQUED -FITTED UPPER SKINS TO SKELETON (NOTE: I DECIDED NOT TO DO SINGLE PIECE UPPER WING SKINS WHEN I RANG OUR LOCAL ALUMINIUM SUPPLIER AND WAS QUOTED $380 PER SHEET)
PICTURES- 548-550 RIVETS - INST 0 - REM 0 WING RIVETS - INST 326 - REM 6 TOTAL PROJECT RIVETS - INST 2541 - REM 53
