EXCEPTIONS/NOTES -ELEVATOR COUNTERWEIGHTS NOT SECURED, WAITING ON HARDWARE -TRIM TAB HINGE PIN, LONGER PIN NEEDS TO BE INSTALLED & LOCKWIRED -ELECTRIC TRIM SYSTEM NEEDS TO BE ATTACHED/ADJUSTED -ROD END BEARINGS IN RUDDER REQUIRE LENGTH SETTING -NO SWING, ALIGNMENT CHECKS CARRIED OUT -HORI STAB CENTRE BEARING TOELEV HORNS NOT DRILLED -NO BOLTS TORQUED
PICTURES- 177-186 RIVETS - INST 0 - REM 0 ELEVATOR TOTAL RIVETS - INST 2215 - REM 49 TOTAL PROJECT RIVETS - INST 2215 - REM 49
