Brief Description: ELECTRIC TRIM ASSY CONSTRUCTION
-MEASURED ELECTRIC TRIM BRACKETS TO PANEL & CHANGED AS REQUIRED DUE TO MIRROR IMAGE ISSUES WITH THE PLANS -DRILLED BRACKETS TO PANEL -PRIMED BRACKETS -ROLLED RH ELEVATOR LEADING EDGE -FITTED RH ELEVATOR TO HORIZ STAB & REMOVED REQUIRED MATERIAL
PICTURES- 133-139 RIVETS - INST 0 - REM 0 TOTAL PROJECT RIVETS - INST 2137 - REM 42
