-CLECOED/DRILLED 610/611 PLATES TO SPAR -FLUTED/DEBURRED 704/5 TIP RIBS THEN DRILLED TO SPAR -RIVETED STIFFENERS TO LHS SKIN EXCEPT UPPER JKL IN TRANSIT FROM VANS -MODIFIED DIMPLE DIE, DIMPLED PLATENUTS & RIVETED TO 615 PLATE -RIVETED 615 PLATE TO SKIN -DRILLED COUNTEBALANCE TO TO RIB/SKIN ASSY -CLECOED SKELETON STRUCTURE TOGETHER -FINAL DRILLED ROOT RIB & HORN TO STRUCTURE -CLECOED SKIN TO SKELETON -FINAL DRILLED UPPER HALF
PICTURES- 107-115 RIVETS - INST 112 - REM 0 TOTAL PROJECT RIVETS - INST 1939 - REM 39
