Riveted HS707 to top side of the skin then bottom side Clecoed Spar assy on then blind riveted 404-702-405 Installed spar to tip rib rivets Riveted Assy together Repeated for RHS While Riveteing RH HS706 to spar, rib became damaged, removed it pending replacement
