THE PRIMER IS NOW DRY ON THE VA146 BEARING SO I RIVETED THE HS411'S AROUND THE BEARING WITH A -5 RIVET FOR THE FIRST RIVET, BUT LIKE MANY OTHER BUILDERS I WASN'T HAPPY WITH THE SHOP HEAD SO I DRILLED IT OUT AND DID ALL THE RIVETS WITH -6. (Refer DfD-0001) -NEXT I CLECOED THE HS411 ASSEMBLY TO THE SPAR & ENLARGED THE ATTACHMENT HOLES TO #12 SIZE. -I THEN MARKED THE PARTS
