TODAY I -TRIMMED THE IB ENDS OF 2ND HS702 AS PER "FRONT SPAR TAB DETAIL" DRAWING 3 -MARKED BEND LINE AND CUT RELIEF NOTCH ON HS702 #2 -I FOUND SOME DEEP SCRATCHING AT THE RELIEF NOTCH ON HS702 #1 SO I HAVE BLENDED THEM OUT AND EMAILED VANS WITH MEASUREMENTS AND PHOTOS -WHILE I WAIT FOR THE RESULTS FROM VANS I'LL BUILD ON AND REDO HS702 #1 IF NEED BE. -BENT TABS ON HS 702 #1&2 AS PER VIEW B-B DRAWING 3 -COUNTERSUNK CENTER FOUR HOLES ON HS710 & 714 & DIMPLED CENTER FOUR HOLES ON HS702.
