Brief Description: FINISHING LEADING EDGE, STARTING TO FIT FUEL TANK
-FLIPPED WING OVER TO MAKE RIVETING EASIER -RIVETED 3x INBOARD RIBS TO SPAR -RIVETED THE LOWER SPANWISE ROW OF RIVETS -INSTALLED FUEL TANK ASSY & DECIDED TO INSTALL ALL SCREWS AND BOLTS INSTED OF THE HALF THE MANUAL CALLS OUT, I CAN'T SE WHY TO ONLY PUT HALF IN & ALL I CAN SEE THAT DOING IS CAUSING HOLE MISALIGNMENT ISSUES WHEN I TRY TO PUT ALL THE OTHERS IN. -INSTALLED ALL SCREWS AND BOLTS LOOSELY, ONCE ALL WERE IN STARTED TO RUN SCREWS DOWN BUT DIDN'T LIKE BULGES I WAS GETTING BETWEEN SCREWS AT FUEL TANK SPLICE PLATE. -REMOVED FUEL TANK AND MEASURED SPLICE & WHERE SEALANT ENDS ON TANK AND FOUND THAT THE SEALANT WAS INTERFERING WITH THE SPLICE PLATE -REMOVED A SMALL AMOUNT OF EXCESS SEALANT FROM THE TANK & A SMALL AMOUNT OF MATERIAL FROM THE SPLICE PLATE -HIT ALL BARE MATING SURFACES WITH THE ALODINE PEN -REFITTED, STILL NOT HAPPY SO REMOVED AGAIN
PICTURES- 1727-31 GOPRO PICTURES RIVETS - INST 80 - REM 0 WING RIVETS - INST 1334 - REM 33 TOTAL PROJECT RIVETS - INST 3655 - REM 86
