-CUT TIEDOWN SPACERS OUT OF SUPPLIED BAR -DRILLED LIGHTING HOLE OUT OF SPACERS -MEASURED AND DRILLED REFERENCE POINT ON 731 TIEDOWN BAR -CLAMPED SPACERS AND TIEDOWN BAR TO SPAR AND DRILLED ATTACH HOLES -DRILLED COUNTERSUNK ASSY FOR PLATENUTS -PREPPED SPACERS & TIEDOWN BAR FOR PRIMING
REAR SPAR -FOUND SOME LIGHT CORROSION ON THE REAR SPAR CHANNEL WHEN I REMOVED THE VINYL. -CORROSION REMOVED REFER DFD23 -MARKED & TRIMMED 707D & G AS PER DWG 38 -EDGE DEBURRED SPAR, REINFORCEMENT FORK & REINFORCEMENT PLATES -MATCH DRILLED DOUBLER PLATES TO SPAR -CUT OUT AILERON PUSHROD HOLE IN DOUBLER -INSTALLED AND MATCH DRILLED REINFORCEMENT FORK AND PLATE
PICTURES- 1707-1714 GOPRO PICTURES RIVETS - INST 0 - REM 0 WING RIVETS - INST 1142 - REM 33 TOTAL PROJECT RIVETS - INST 3461 - REM 86
