-DRILLED AND TAPPED PITOT TUBE/MAST -MATCH REAMED LEADING EDGE ASSY. -ENLARGED TIEDOWN HOLE IN SKIN TO 7/16", THE HOLE ENDED UP NICE AND CENTRAL ON THE TIEDOWN ASSY -SUMMER'S STARTING TO HIT SO ITS GETTING HARD TO SPEND EXTENDED PERIODS OF TIME IN THE SHED WITH IT BEING OVER 40 DEGREES C (104 DEGREES F) INSIDE
PICTURES- 561-564 RIVETS - INST 0 - REM 0 WING RIVETS - INST 326 - REM 6 TOTAL PROJECT RIVETS - INST 2541 - REM 53
