Tarans RV7 Project - VH-TJL
Date:  11-19-2014
Number of Hours:  3.00
Manual Reference:  7-4
Brief Description:  LH WING FITTING UPPER SKIN
-CUT BOTH WING WALK DOUBLERS TO SIZE
-DRILLED SKIN TO DOUBLER
-SECURED MAIN SPAR INTO STAND
-TAPPED TIE DOWN ASSY
-FITTED TIE DOWN ASSY/ AILERON BELLCRANK BRACKETS WITH CENTER FOUR BOLTS AND TORQUED
-FITTED UPPER SKINS TO SKELETON (NOTE: I DECIDED NOT TO DO SINGLE PIECE UPPER WING SKINS WHEN I RANG OUR LOCAL ALUMINIUM SUPPLIER AND WAS QUOTED $380 PER SHEET)
PICTURES- 548-550
RIVETS - INST 0 - REM 0
WING RIVETS - INST 326 - REM 6
TOTAL PROJECT RIVETS - INST 2541 - REM 53
WING WALK DOUBLER DRILLED
UPPER SKIN FITTED
UPPER SKIN FITTED
