Brief Description: Right fuel Tank Assembly - Continued
-Finished drilling the Z-Brackets to the spar -Removed brackets -Unfortunately when i previously restarted my brackets on the left side i didnt reorder the nutplates, so i needed to try and locate the old brackets and remove the nuts from them -Removed nuts from old plates -Still short 4x nuts so i'll have to order more but i can make do for the time being -Also couldnt't find my nutplate drill gauge so I made a new one and started drilling z-plate holes -Drilled all the Nutplate holes but also can't find my 3/32 countersinking cutter so can't really do much without that
