-CLEANED UP LIGHTENING HOLE/EDGES ON FLAP SPARS -DRILLED & CLECOED RIBS TO SPARS -FABRICATED FL708 SHIMS -THE RIBS WERE ALL CONTACTING THE REAR SPAR SO NO SHIMS WERE REQUIRED -DRILLED RIBS TO REAR SPAR -DRILLED RIBS TO BOTTOM SKIN -MARKED 1/4" LINE ON HINGES TO GET ALIGNMENT AND EDGE DISTANCE GOOD FOR DRILLING. -CLAMPED AND DRILLED HINGES TO FLAP ASSY -FITTED UPPER SKINS AND DRILLED FL-709 SHIMS TO ASSY
PICTURES- 9601-9606 RIVETS - INST 0 REM 0 WING RIVETS - INST 2683 REM 57 TOTAL PROJECT RIVETS - INST 5000 REM 109
