-REMOVED VINYL FROM INSIDE OF FUEL TANK SKIN -STARTED REMOVING VINYL FROM REAR TANK BAFFLE BUT UNDERESTIMATED THE STRENGTH OF THE ADHESIVE AND ENDED UP BUCKLING THE BAFFLE -TRIED STRAIGHTENING THE REAR BAFFLE BUT NOT SATISFIED SO I'LL HAVE TO ORDER A NEW ONE -STARTED FITTING RIBS INTO SKIN, DIDN'T WORK OUT AS EASY AS BEFORE, ENDED UP CLECOING TOP ROW, FITTING INTO CRADLE THEN TEMPORARILY FITTING THE REAR BAFFLE TO PUSH RIBS INTO PLACE WHILE I CLECO THEM. -MARKED CENTRE LINES ON THE Z-BRACKETS & DRILLED CENTER HOLE
PICTURES- 9588-9589 RIVETS - INST 0 REM 0 WING RIVETS - INST 2547 REM 53 TOTAL PROJECT RIVETS - INST 4864 REM 105
