Tarans RV7 Project - VH-TJL
Date:  5-23-2020
Number of Hours:  2.50
Manual Reference:  dfd21
Brief Description:  STARTING RH FUEL TANK
-REMOVED VINYL FROM INSIDE OF FUEL TANK SKIN
-STARTED REMOVING VINYL FROM REAR TANK BAFFLE BUT UNDERESTIMATED THE STRENGTH OF THE ADHESIVE AND ENDED UP BUCKLING THE BAFFLE
-TRIED STRAIGHTENING THE REAR BAFFLE BUT NOT SATISFIED SO I'LL HAVE TO ORDER A NEW ONE
-STARTED FITTING RIBS INTO SKIN, DIDN'T WORK OUT AS EASY AS BEFORE, ENDED UP CLECOING TOP ROW, FITTING INTO CRADLE THEN TEMPORARILY FITTING THE REAR BAFFLE TO PUSH RIBS INTO PLACE WHILE I CLECO THEM.
-MARKED CENTRE LINES ON THE Z-BRACKETS & DRILLED CENTER HOLE
PICTURES- 9588-9589
RIVETS - INST 0 REM 0
WING RIVETS - INST 2547 REM 53
TOTAL PROJECT RIVETS - INST 4864 REM 105
BUCKLED BAFFLE
BUCKLED BAFFLE
INSTALLING CLECOS
INSTALLING CLECOS
Z- BRACKETS DRILLED
Z- BRACKETS DRILLED
