-REMOVED VINYL FROM INSIDE RH LEADING EDGE -MOUNTED IN CRADLE -CLECOED RIBS IN PLACE (THOSE LOWER CLECOES WERE PAINFUL TO TRY AND LINE UP) -MOUNTED ON MAIN SPAR AND CLECOED IN PLACE -SLID IB RIB INTO PLACE AND BACKDRILLED TO SPAR -MEASURED, MARKED AND FITTED W423 SPLICE PLATE -LINED UP IB RIB AND SPLICE PLATE AND DRILLED/CLECOED IB RIB TO SKIN & SPLICE PLATE -MATCH REAMED ALL RIBS TO SKIN -EXTENDED TIEDOWN LINES & OPENED UP TO 7/16"
START 11.15
PICTURES- 9582-9587 RIVETS - INST 0 REM 0 WING RIVETS - INST 2547 REM 53 TOTAL PROJECT RIVETS - INST 4864 REM 105
