Brief Description: BACK TO WORK, DRILLING RWING LWR SKINS
FINALLY GOT TIME TO GET BACK INTO THE RV WITH BEING STOOD DOWN FROM WORK -CLEANED UP THE WORK AREA -LUBED UP ALL AIR TOOLS -CLEANED THE DUST OFF THE WING -TOOK A BIT TO FIGURE OUT WHERE I'M AT -IT LOOKS LIKE LAST TIME I WORKED I FITTED THE LWR RIGHT WING SKINS AND MATCH DRILLED MOST HOLES -MOVED CLECOS OVER AND FINISHED MATCH DRILLING LWR MAIN SKINS -TAPPED TIE DOWN ASSY -FITTED TIE DOWN ASSY/ AILERON BELLCRANK BRACKETS WITH ALL 8 BOLTS AND TORQUED -MARKED TIEDOWN LINES -REMOVED LWR SKINS
PICTURES- 9575-9581 RIVETS - INST 0 REM 0 WING RIVETS - INST 2547 REM 53 TOTAL PROJECT RIVETS - INST 4864 REM 105
