-CLECOED TOP SKINS IN PLACE, FOUND THAT I HADN'T DRILLED SPAR CHANNEL TO SPAR REINFORCEMENT PLATES SO REMOVED THE OUTER SKIN DRILLED THOSE AND REATTACHED OUTER SKIN. -DUE TO THE OTHER WING STILL BEING IN THE STAND THIS WING HAS TO BE WORKED ON THE BENCH WHICH MAKES MOST THINGS AWKWARD. -DRILLED 1ST SET OF HOLES IN UPPER SKINS, NEED TO MOVE CLECOS AND DRILL THE REST BUT MY ARMS ARE TIRED FROM REACHING OVER THE WHOLE THING WITH A DRILL SO IT CAN WAIT FOR ANOTHER DAY
PICTURES- 9545-47 RIVETS - INST 0 REM 0 WING RIVETS - INST 2328 REM 47 TOTAL PROJECT RIVETS - INST 4645 REM 99
