JUSTIN'S WEB SITE
Date:  8-16-2011
Number of Hours:  5.00
Brief Description:  Began rudder work
Still don't have any primer so I began work on the rudder. I started by cutting the rudder stiffeners and then polished them using the scotchbrite wheel. This is very tedious work and took awhile but I was able to finish pretty quickly. I then went at match-drilled all of the stiffeners to the rudder skin. I also deburred all of the parts. When the primer arrives I'll prime the skins and the stiffeners then begin backriveting.
The band saw makes quick work but leaves a pretty rough edge to cleam up with the scotchbrite wheel.
"Connecting the dots" so to speak
All the parts cut to length.
