Brief Description: Primed Vertical Stabilizer Skin, Started Assembly
Cleaned and started priming the vertical stablizer skin. I decided again to just prime the main joint lines where contact will occur and lightly prime the rest of the inside, better than nothing right? While the primer was drying I went ahead and squeezed the skeleton together. My brother stopped by so we I talked to him for awhile while the primer continued drying. I ended up pounding a few rivets but it was getting late so I called it quits for the night.
Scuffed up the inside skin and washed and cleaned it.
Skin after priming.
Assembled the skeleton while I waited for the skin to dry.
