The directions are pretty vauge on how to drill these holes for the HS404/HS702/HS405/HS-810-1. I mulled it over last night and decided to wait until I had the skins on so I can get it lined up better. It was a pretty smart move and enable me to get the 404 and 405 lined up with the skin. I was able to use that long 12" bit to drill the necessary holes between HS404 and the front spar. These turned out pretty well. Having a lot of these little 1" and 1.5" side clamps work really well for these tasks.
Test fitting the HS404 and trying to figure out the french that Van's throws at you for this step
HS405 fit
Drilled these holes and am happy how they turned out.
