Brief Description: Rear and Front Spar Horz Stab Buildup
Began the assembly of the rear spar. Matchdrilled all of the HS-609PPs holes to the HS-603PP. Also fit all of the elevator attach brackets and match drilled those. Went really smooth. I went ahead and decided to prime the VA-146 bearing housing and will wait for assemly till tomorrow when its completely dry.
